Cummins 5.9 liter 6BTA Marine problems
Old 08-09-2012, 07:05 PM
Azrial's Avatar
Default Cummins 5.9 liter 6BTA Marine problems
My friend has a pair of Cummins 5.9 liter 6BTA six cylinder diesels on his boat. One of them is making no power and his mechanic is stumped!
They have just replaced the turbo with a rebuilt unit and put a new intercooler on it and this has not resolved the problem. He is only making about 5 PSI boost and believes he should be making 20-30 PSI. He has no real power out of this motor like its mate, even though otherwise the motor runs fine.
I am no diesel mechanic but assumed that it would be the waste gate, but he says that his model does not have one.
We spent all of the Rockdale Regatta in port and he has already spent thousands and still not resolved this problem. Any ideas?
Old 08-09-2012, 09:35 PM
tiremann9669's Avatar
Have you checked fuel pressure ?
H.R.D (08-09-2012)
Old 08-09-2012, 10:10 PM
H.R.D's Avatar
Originally Posted by Azrial
My friend has a pair of Cummings 5.9 liter 6BTA six cylinder diesels on his boat. One of them is making no power and his mechanic is stumped!
Not going to harp on you too much about it but Cummins doesn't havt a G in it.
Okay, now I agree with TMan check fuel pressure. You need fuel to create boost.
Old 08-10-2012, 08:28 AM
cummins_guy's Avatar
3rd on the fuel.
if you need anymore help
571-230-8044
Mike
Old 08-10-2012, 08:59 AM
RAW's Avatar
RAW
RAW is offline
Check fuel pressure and all boost tube/hose connections.
When was the fuel filter for that engine last done?
What fuel system is on this engine?
Any performance modifications?
Does it smoke?
Azrial (08-16-2012)
Old 08-10-2012, 04:56 PM
Azrial's Avatar
Thanks Mike! My friend is Travis and I have passed on your number! I am back in Atlanta and he and the boat are still in Charleston.
OK, regarding the fuel pressure, at this point the tested pressure is an unknown. However the diaphragm, injectors and filters are new, so I guess that he assumed that he had that base covered.
His intake boost pressure is 0 PSI under load and 30 PSI under no-load. The engine will runs up to 1900 RPM and will do no more under load. His oil pressure, volts, and temperature are good and his exhaust system is unrestricted. For what it is worth he also have fresh coolant, and a new water pump and impeller.
He is getting ready to test the fuel pressure today! Thanks for the help so far!
Let's see, more info for the collective mind.
There are no mods to the motor and the fuel injection is the standard unit for this application. I do not know otherwise how to describe it.
All the hoses and seals are tight under load.
The fuel lines are all high pressure steel and are not kinked. We are testing the pick-up tube screen in the tank at this time for trapped sediment.
The injectors have been pulled and they are all clean and dry on the tips.
The motor have two fuel pumps for two motors. The motors have new air filters. The throttle has been checked, the Throttle body plate shaft is not bent and the throttle cable pulls it open all the way.
That is about it for now, still checking fuel pressure and getting ready to blow out the pick-up line in the tank with compressed air. I will keep you advised, and thanks! : )
BTW, the motor does not smoke.
Old 08-14-2012, 08:23 PM
Azrial's Avatar
Well guys, fuel pressure is good and the fuel lines have been blown out and the Racors cleaned. The bottom line is the same, no power on that engine. The mechanic, my buddy, and I are all stymied.
Any other ideas?
Old 08-16-2012, 10:44 AM
my cell phone was droped in water, will have a new one theis monday.
you can have your mechanic call the office
703-641-0400 x205
Azrial (08-16-2012)
Blake35
01-30-2016 11:29 PM
jmont61
Potential Diesel Owners Forum
01-22-2016 07:29 PM
SimpleMan1301
01-09-2016 02:47 PM
plumberjack
29
03-03-2015 11:38 PM
dezeldoc
For Sale
02-02-2015 04:21 PM
Quick Reply: Cummins 5.9 liter 6BTA Marine problems
