oil leaking out of my front axle???
Old 08-31-2012, 04:57 PM
94Cumminz's Avatar
Default oil leaking out of my front axle???
there is oil leaking from the front axle drive shaft that connects to the wheel? is it a seal?
its on my 1996 auto in my sig
Old 08-31-2012, 06:12 PM
H.R.D's Avatar
More than likely it will be the front pinion seal.
This video should help you out.
Old 09-01-2012, 01:14 AM
ricet07's Avatar
Your post is confusing because you say drive shaft, axle and by the wheel. If it is where the front driveshaft (coming from transfer case going to front differential) then it is the front pinion seal and the above video will help you out. I believe you are talking about a seal leaking where the axle knuckles are by the front hub/wheel assembly. If so, yes there are seals aroung the axles and they will leak. Hopefully it is a pinion seal though because axle seals are a PITA, good luck.
H.R.D (09-06-2012)
Old 09-01-2012, 12:45 PM
94Cumminz's Avatar
sorry for the confusion. its leaking by the axle knuckles. it drips on my front driver side wheel.
Old 09-01-2012, 07:49 PM
ricet07's Avatar
Axle seal
Old 09-06-2012, 09:19 AM
1AMatt's Avatar
Site Sponsor - 1aauto
X2 Driver side axle seal
Old 09-07-2012, 12:10 AM
94Cumminz's Avatar
well i figured it out. the diff was over filled and the extra came out on the drivers side. it doesn't leak anymore.
dieselnut73 (11-05-2012)
Old 09-17-2012, 08:37 AM
P-Pump's Avatar
my axle seal was leaking too kept puttin the oil to her n she stopped leaking after a week or so
Paul08
Ford Powerstroke 08-10 6.4L
05-09-2021 11:01 AM
soco
07-27-2015 06:06 PM
Natenelson1
01-19-2015 07:23 PM
KYLEBOY
01-18-2015 06:36 PM
natenel1
10-26-2014 03:09 AM
Quick Reply: oil leaking out of my front axle???
