Truck not turning over! Need HELP!!
Old 09-01-2012, 01:54 AM
DieselBabe's Avatar
Default Truck not turning over! Need HELP!!
I have a 2003 ford f-250 7.3 powerstroke. i replaced my hpop and now it wont turn over. I am at a loss and i have no idea what to do next i need it to start!! anyone can help me with my problem??
Old 09-01-2012, 08:47 AM
EricC's Avatar
You may want to post this under the 99-03 tag as well. May be more 7.3 guys over there
Old 09-01-2012, 10:17 AM
I'll move this to the 7.3 section for you. Probably left a connection loose somewhere.
I changed the title of your thread, there is no swearing allowed in the open forums here. Thanks, and welcome to DB!
Old 09-01-2012, 05:20 PM
I have a question also. Is the resvoir suppossed to drain after cranking? Because I saw somewhere that I'd have to refill it. (We're working on the same truck)
Old 09-03-2012, 09:14 AM
What electrical connections did you mess with while replacing your HPOP? Does the starter sound like its trying to turn the motor over and it can't? Or do you have nothing when you turn the key?
Old 09-04-2012, 01:33 PM
Smokey Freedom's Avatar
Define "Not turning over". Need to clearify if you mean wont start or physically not turning over.
When you pull the pump the reservoir drains and you need to refill it otherwise you'll be cranking forever to get a prime on the new pump. Fills by pulling that allen drive plug on the top. Wont fill completely full either (w/in a 1/2"ish). IMHO you should pull the reservoir and clean the debit screen thats part of the lower gasket now while its drained.
JSATCT860
Towing and Hauling
06-15-2015 11:21 PM
clarthom
8
03-05-2015 07:27 PM
mountainmover
Big Rigs & Semis
03-01-2015 06:03 AM
12-03-2014 09:40 AM
10-14-2014 08:40 AM
Quick Reply: Truck not turning over! Need HELP!!
