Speed sensor location
Old 09-05-2012, 01:40 PM
happyred1972's Avatar
Default Speed sensor location
I have a 2004 dodge 3500 with a 6 speed...My speedometer is jumping, replaced the one in the rear end. Did not fix it.....Is there another sensor somewhere and where do I find it? The auto parts stores are not showing any other ones..
Thanks
Old 09-05-2012, 02:40 PM
dmaxjenn's Avatar
IT'S A GIRL!
The speed sensor is located in the overdrive gear case. The sensor is positioned over the park gear and monitors transmission output shaft rotating speed
Old 09-05-2012, 02:45 PM
biged681985's Avatar
It's most likely the gauge cluster. It is a common problem
Old 09-05-2012, 02:56 PM
dmaxjenn's Avatar
IT'S A GIRL!
i remember the recall on the o4 dmax , should check for a tsb on that might be able to get it done free? i did!
cjt8569
09-29-2015 06:39 PM
Dertyd
24
06-07-2015 02:45 PM
Taylor03
06-06-2015 11:09 AM
05-17-2015 12:10 PM
F250MACH
04-26-2015 05:19 PM
Quick Reply: Speed sensor location
