Turbo Tuning?
Old 09-24-2012, 08:39 AM
SRTcummins's Avatar
Default Turbo Tuning?
If i adjust the wastegate will my boost increase? is the turbo on the cummins comp controlled?
My caliber srt4's turbo can be controlled through the pcm or wastegate. but the pcm will limit if boost is too high
Old 09-24-2012, 08:57 AM
wyodiesel92's Avatar
Your edge juice should have come with an elbow to allow more boost. Boost elbows are about as much as you can do. Or put on a bank big head gate
Old 09-26-2012, 08:20 AM
SRTcummins's Avatar
I bought the chip used so i didnt get one. What are my options now? J hook or a different wastegate. i smoke in all gears when im on it and the turbo spools to 17-19 max on level 5. So im guessing the added boost should get rid of that because it should blow smoke at high rpm's
Old 09-26-2012, 12:37 PM
53Blocked's Avatar
You can buy boost elbows online. My edge on level 5 can hit 35 psi in a hurry and gets rid of almost all the smoke. I ran mine before and after the elbow instal and it makes a world of difference with it instaled.
Old 09-26-2012, 12:48 PM
Farmboy 2.0's Avatar
Those elbows are like $32 bucks shipped. Is your truck a auto or manual?
Old 09-27-2012, 12:24 PM
scottmorgan's Avatar
just buy a gate vavle and the right npt fitting and close the valve off little at time till you get the right boost levels. i have done this. i have two of them one with a neelde vavle and one with a gate vavle. i found the gate vavle opens slower witch helps get the right boost levels.
i spent 10 dollars in my local hard ware store for both of them.
Old 09-27-2012, 01:23 PM
shellinger's Avatar
with my quadzilla adrenaline on 10 i have hit 41 lbs of boost. and all my elbows are stock
Old 09-27-2012, 03:49 PM
EggosBrother's Avatar
TST sells their jhook for $10 or $15. super easy to install. works great.
Old 09-27-2012, 10:10 PM
I hook for an auto, elbow for a manual unless the auto has a hx35
avatardvr
18
08-08-2019 12:38 AM
Grey Rhino
08-12-2015 06:47 AM
n2brk
02-21-2015 09:05 AM
jrsavoie
02-06-2015 09:44 PM
GreenDieselF
10-20-2014 02:05 PM
Quick Reply: Turbo Tuning?
