what else is needed?
You will have to mount the linkage in a different spot on the frame had to move mine one hole back. only had to drill one hole. I was able to use my rear driveshaft but had to have the front rebuilt (wornout) and they made it longer. If going in a 4x4 the 4x4 shifter may need spacers to offset the shift mount as on some the cases are different. 1/2" to 3/4" spacer for the 3 mounting bolts. I didn't change the controller. Only have a manual on/off lockup
bladeyamaha (10-25-2012)
Ok thank you. I already have OD in my truck, so i just need the ability to lockup. Anything for the 46 will work with some modifications for the 47? Other thing the "throttle" cable for the trans, what did you do with it? is it a push not pull type? May PM you a little later on when i get to the build on some "what did you do" thanks
Strictly Diesel
Strictly Diesel
06-30-2015 06:48 PM
klein444
06-20-2015 11:48 PM
