2002 Ford F350 Diesel 7.3l Oil Leak Need Help
Old 11-09-2012, 04:12 PM
Sewzan77's Avatar
Default 2002 Ford F350 Diesel 7.3l Oil Leak Need Help
Ok guys I am just a silly Gurl so keep the help simple. I have an oil leak at the back of the motor, at the top, looks like it is leaking from under the Turbo Motor. Any Suggestions?
Old 11-09-2012, 06:44 PM
doorman2012's Avatar
check your oil cooler might need to reseal
Old 11-09-2012, 07:17 PM
bowietrucking's Avatar
try and clean it up with some brakeclean and try and see exactly where its coming from. it may be fuel, not oil.
Old 11-12-2012, 12:31 AM
could be turbo pedestal o-rings, or as simple as the air intake spider boots leaking oil and running down the lip of the intake plenum and into the valley or down the back.
Old 11-12-2012, 04:14 PM
CSIPSD's Avatar
More then likely its a turbo pedistal leak, but it could be the exhaust back pressure valve rod.
As others have said, clean the area really well and drive. You should be able to pin point the area better.
Pulling the turbo is not hard, can be done with basic driveway tools.
makuloco2000
12-20-2015 11:19 PM
88 f350 7.3 idi
08-20-2015 09:18 AM
Dye Guardian
08-01-2015 01:28 PM
ash23k
12-30-2014 08:31 PM
12-10-2014 08:10 AM
Quick Reply: 2002 Ford F350 Diesel 7.3l Oil Leak Need Help
