94 cummins studder
Old 11-18-2012, 09:07 PM
Mikey81's Avatar
Default 94 cummins studder
i have a new to me 94 cummins 4x4 right around 1000-1300 its got a real stutter that completely disappears from 1300 on up and no idle issues. motor has 370 injectors and a #7 fuel plate. i also noticed the person who owned it prior added an inline fuel pump but have no clue the brand or if it is even for a diesel application could this be my problem. i unfortunately do not have a fuel pressure gauge. thanks for any help
Old 11-29-2012, 09:06 PM
Red_Rattler's Avatar
High Tech Redneck
any smoke with the studder? and like you said a pressure gauge would help a ton
Old 11-30-2012, 09:36 AM
captain_stabbin's Avatar
all 160 pumps have a lil miss like to them at about 1200
Old 11-30-2012, 10:52 AM
1993firstgennewbie's Avatar
Check your crank sensor
Old 11-30-2012, 09:36 PM
angelic0-'s Avatar
How would that matter on a P-Pump motor, all the CPS does is give a tachometer reading ?
Red_Rattler (12-01-2012)
Old 11-30-2012, 11:48 PM
correct^^
Old 11-30-2012, 11:50 PM
1stgenblowingsmoke's Avatar
I'd check fuel pressure. Should be about 17 at idle n 27 at WOT.
Old 12-02-2012, 01:25 PM
Al31031's Avatar
has the timing been screwed with at all because i accidently bumped mine to like 20 degrees and she had a lil shutter around 1500 but brought it back 19.5 and went right away
Shun70
Diesel Engine Conversions
09-21-2015 01:39 AM
Sbboozer
11-16-2014 05:52 PM
10-31-2014 08:10 AM
10-24-2014 04:40 AM
Omingnome
10-20-2014 12:25 PM
Quick Reply: 94 cummins studder
