Power Steering issues
Old 11-29-2012, 08:41 AM
turbodrivingarmyboy's Avatar
Default Power Steering issues
I have a 2002 f350 7.3 power steering fluid sprayed all over the driver side tire. i found the hose thats leaking, its the one that runs on the frame to the front of the truck does anyone have an idea what this hose is? I feel like it connects to the mcyl but not sure it was dark out last night when it happened.
Old 10-19-2013, 06:45 PM
N.Rush's Avatar
High pressure line. Goto napa and theyll hook you up.
Old 10-22-2013, 12:17 PM
tiremann9669's Avatar
If it runs to the front of the truck it's probably a cooler hose
Old 11-05-2013, 02:35 PM
Coz17's Avatar
same thing happened to mine. I lost all power steering and brakes. it was my high pressure line and cost like 40 bucks and now its fine. just make sure if that's the problem that you bleed the line when you replace it
Old 11-15-2013, 12:49 PM
TNich's Avatar
Mine is tough to turn at idle but once I start bringing up the rpm it steers fine. Could mine need new lines or is it the power steering pump?
Old 12-14-2013, 10:57 AM
tuey1911's Avatar
I have the same issue as TNich any solutions.....it also whins alot when i turn it to
Antwhite19
08-23-2015 06:07 AM
ramrunner01
06-01-2015 12:10 AM
krg3590
03-15-2015 08:57 AM
1MooseheadPlease
10-13-2014 05:33 AM
sweetv8s10
10-07-2014 09:47 PM
Quick Reply: Power Steering issues
