piston style lift pump swap worth it?
Old 12-02-2012, 02:07 AM
sootman's Avatar
Default piston style lift pump swap worth it?
I was snoopinga around online because my lift pump started leaking fuel. I saw a kit to convert to the piston style lift pump for $270. Is it reallt worth it or save up for a raptor lift pump?
Old 12-02-2012, 03:39 AM
hydroshok's Avatar
Depends on how much HP you want to eventually make. It is said to support ~300HP. If it's leaking don't keep driving it with low pressure because it will wear out the injection pump. I have the kit on my 1st gen and it works just fine with my setup (listed in my sig).
Old 12-02-2012, 09:37 AM
bladeyamaha's Avatar
Uh, I think it is, you just prolly don't need those lines get an aftermarket fuel filter (remote mount like Racor) just buy the spacer and the pump, spend less on those, bypass all the stock filter and the fuel heater if its not really needed, its what I'm doing, but I'm in South Texas and winters aren't much here. Remember the electric fuel pumps would be whining the whole time you have the engine on, it seems to me it would get real old.
Old 12-02-2012, 11:07 AM
BC847's Avatar
Get a better quality electric fuel-pump.
Old 12-02-2012, 09:53 PM
AHineman's Avatar
I can hear the Airdog on my truck when I turn the key on, but once I start the engine, all I hear is 12 valve music.
Old 12-04-2012, 01:01 AM
1stgenblowingsmoke's Avatar
Just a get a ppump lp, fp regulator for like 15psi tops, some fittings, two pump to block gaskets, make a dpacer just like the gasket I think it's 5/16 thickness and make the lines. then the factory line off the lp cut it n slip a 3/8 hose over it double hose clamp it n call her a day. took me 2 hours on my VE.
Old 12-04-2012, 10:49 AM
Screamin' Metal's Avatar
Like the man said, you'll hear it even if its a holley black or blue pump....but when the music starts, all is fine!
Now then, theres something about filling my crankcase is diesel that rubs me the wrong way, so I always block off the Mech. pump, run a good electric, wired into the Hobbs switch plumbed into theoil system just below the stock oil pressure sending unit.
That way if you ever loose oil pressure, your fuel is cut off.
Best to have plenty of pressure though....its hard on the IP if you don't.....
Old 12-04-2012, 11:12 AM
78fordf150ranger's Avatar
Do please post some pictures
Old 12-04-2012, 06:01 PM
Whichever pump you go with, just don't go over 15 PSI, use a regulator and turn it down to about 12....
bladeyamaha (12-04-2012)
Old 12-05-2012, 10:36 AM
sootman's Avatar
do you have any recommendations on which electric pump to get. i'm just looking for something to support mild injectors and a s300ish turbo till i get everything else fixed then im going to an air dog II
Quick Reply: piston style lift pump swap worth it?
