04' 6.0 vacuum leak noise (turbo)
Old 12-02-2012, 04:37 PM
charles808's Avatar
Default 04' 6.0 vacuum leak noise (turbo)
just got done puting on an egr delete from rcd. i had white smoke and loosing coolent. after install truck started right up but now im getting what sounds like a big vacuum leak from turbo. the turbo seems like it either loosing pressure or just not building it up. by the way no more white smoke.. any thoughts
Old 12-02-2012, 05:25 PM
bobfbigman's Avatar
The most common leak is the Ypipe to turbo connection, it is a pain to get it lined up right without loosening the uppipes.
Old 12-02-2012, 06:40 PM
charles808's Avatar
for me, it was the hardest part of doing the egr delete. did it myself gonna try to get a friend over on monday to help. up or y pipe,thats what im hearing from the nice people helping me here... try it again.. it took me awhile to get the turbo on the mounting braket so it would match up with the y & up pipe. it looked good when i put the clamps back on. ill see. thanks for the help
Old 12-04-2012, 07:36 PM
charles808's Avatar
was the y pipe. it was a pain in the butt. mainly because i did it my self. had to loosen the turbo and use a couple of pry bars but after an hr and half, got it to line up. def a 2 person job, because you need atleast 3 hands in there... thank you
Old 12-05-2012, 07:45 AM
My first EGR delete took me over 12 hours to do, and by the time I was done I was SHOT. Started the truck up and the damn thing had an exhaust leak right at the y-pipe to turbo connection. I was so frustrated I just left it. I probably drove it for a month like that. Finally one day I decided it needed to be addressed. I kicked myself after because it took me all of 30 minutes to get everything seated nice and tight by doing it the RIGHT way .... went for a whole month and it took me hardly any time at all to fix it.
makuloco2000
Ford Powerstroke 99-03 7.3L
12-20-2015 11:19 PM
BeastFromTheEast
Ford Truck and Powerstroke Turbo Diesel Forum
09-14-2015 02:25 PM
BeastFromTheEast
08-04-2015 10:06 AM
smbenoit_79
05-19-2015 01:32 PM
ash23k
12-30-2014 08:31 PM
Quick Reply: 04' 6.0 vacuum leak noise (turbo)
