Odometer/ console issues
Old 12-04-2012, 11:42 AM
iam4x4's Avatar
Default Odometer/ console issues
The truck is a 2005 dodge cummins and the odometer isn't working, 4x4 light doesn't work but does engage. Also the shift indicator does work some times. Does anyone have any ideas? Just fuses? The cable on the diff? Or the instrument panel itself? Any help would be appreciated
Old 12-04-2012, 04:00 PM
minncountryboy's Avatar
In my 06 my tach doesn't work and just recently the cargo lamps quit workin and they are powered through the gauge cluster.. but i know with mine i have to replace the entire cluster its self.. you might have to the same... Electronics could be goin bad. Usually with the dodges if your speed sensor on the diff goes bad then your and light will come on and I'm pretty sure the brake warning light comes on also.... Jist my previous expierence's..
dwmeehan
09-20-2015 03:08 PM
culp7
14
07-20-2015 10:13 PM
ronstop
02-26-2015 09:48 AM
IslanderXJ
12-17-2014 04:14 PM
Polaris04
12-01-2014 08:27 AM
Quick Reply: Odometer/ console issues
