Turbo suggestions
Old 12-07-2012, 11:51 AM
Longhorn2012's Avatar
Default Turbo suggestions
I have a 2012 cummins I deleted everything put a h&s tuner on it and I now got 125 hp injectors on it with a fass fuel system and 85% over pump valve springs and head studs. When I got that done the turbo blew on me I was wondering what's a good turbo to get for that combination of stuff on it I plan on getting a 5.9 manifold. I would like a turbo that can spool up good on the street and be used for 2.6 class pulling. Any suggestions
Old 12-07-2012, 12:20 PM
Farmboy 2.0's Avatar
IIS Silver 66 is a great turbo on the the 6.7L with that setup. I have done numerous 6.7 with this very same setup.
Old 12-07-2012, 01:22 PM
Thanks! Do you think it could spool up a 72 mm without a lot of lag
Old 12-07-2012, 02:05 PM
Do you ever plan on towing with the truck at all? If you do then id stay silver 66 or go S467 with a billet wheel maybe.
Old 12-08-2012, 11:40 PM
jkidd1's Avatar
the s467 will be a nice turbo and is less expensive. Will you be towing?
Old 12-09-2012, 10:00 AM
I will be maybe towing in the future but not now I want a fun street truck that I can use at truck pulls for fun. When I go to tow ill go to twin turbos
Old 12-10-2012, 10:12 AM
Scott would the silver 66 keep my egts low even with a programmer on it
Old 12-10-2012, 10:45 AM
Yes it will and it will run alot cooler even with injectors. Anytime you can remove the crappy restrictive vgt turbo you will see a decrease in egts
avatardvr
18
08-08-2019 12:38 AM
GarrettEvan
01-30-2016 05:39 PM
n2brk
02-21-2015 09:05 AM
billy-bob
5.9L 12V Performance
01-23-2015 08:48 PM
GreenDieselF
10-20-2014 02:05 PM
Quick Reply: Turbo suggestions
