strange issue?
Old 01-03-2013, 01:23 PM
4x4kingx889's Avatar
Default strange issue?
Our 01 3500 had a bad vp44 and the p0216 code..also had a p0234 overboost code put a new vp44 on it all the problems went away and truck runs alot better but also the code's will not go away I also put a boost fooler on for the turbo code had batterys off over night still on and my scanner won't clear them even if the engine is not running the light is not on just when you scan it I can't get them to go away
Old 01-03-2013, 01:54 PM
RAW's Avatar
RAW
RAW is offline
Have you tried another scanner/code reader?
Old 01-03-2013, 02:00 PM
This is the only one I have but wouldn't the battery's off cleared it?
Old 01-03-2013, 02:09 PM
mysterync's Avatar
Ive seen keyway misalignment issues as well as incorrect keyways cause a p0216
Old 01-03-2013, 02:21 PM
In don't think its that because then other code wont clear also and it won't even clear if engine is off
Old 01-03-2013, 02:26 PM
mysterync's Avatar
Are you using a scan tool with bidirectional communication?
Old 01-03-2013, 02:37 PM
I am using a elm32 Bluetooth scanner
Old 01-03-2013, 02:46 PM
mysterync's Avatar
I have no previous experience with that tool. Do you have the ability to see code status?
Old 01-03-2013, 03:33 PM
what do you mean by code status? If you mean if it displays what the problem is then yes it shows it
Old 01-03-2013, 03:59 PM
RAW's Avatar
RAW
RAW is offline
Active or stored is what I think he means.
Quick Reply: strange issue?
