White smoke
Old 01-08-2013, 06:11 PM
66riviera's Avatar
Default White smoke
i have z 92 6.5 turbo 3500 if would stumble a bit when I revv it up and it idles down nod it idles rough and blows black smoke any help would b great
Old 01-08-2013, 08:26 PM
racer55's Avatar
Injectors ever been changed?
IP ever been changed?
How does it start hot?
Old 01-08-2013, 08:53 PM
66riviera's Avatar
Injectors havent been changed starts fine hot or cold
Old 01-08-2013, 09:03 PM
racer55's Avatar
Black smoke is too much fuel,could be leaking injectors or injectors that are popping off too early?
Or a dirty air filter.
Old 01-08-2013, 09:24 PM
66riviera's Avatar
White smoke sorry
Old 01-08-2013, 09:28 PM
racer55's Avatar
Any bubbles in the rad when running?
Does the upper rad hose get hard as soon as you start a cold engine?If so then likely a blown head gasket or cracked cylinder head.
Could also be incomplete combustion if it only does it cold and be caused by non working glow plugs?
acesneights1's Avatar
Does the smoke smell like fuel or does it smell sweet ?
Old 01-09-2013, 04:41 AM
66riviera's Avatar
I also get diesel in crank case it smokes white immediate after starting
Old 01-09-2013, 07:41 AM
racer55's Avatar
Non working glow plugs in some cylinders along with pissing injectors is a good bet.
Old 01-09-2013, 07:08 PM
cviola2005's Avatar
If you have no problems with the cooling system, you could try to adjust your IP timing. I'd venture a guess to say that it needs a complete rebuild.
Quick Reply: White smoke
