275k
Old 01-14-2013, 02:30 AM
USNavy2012's Avatar
Default 275k
Can I safely put a tuner on my 01 Cummins with 275k without causing damage to the engine?
Old 01-14-2013, 04:19 AM
1999stroker's Avatar
First things first. Do ypu have a aftermarket lift pump? Hoe about gauges? If not get those to things first. At least a fuel pressure gauge,trans temp if auto,boost,pyro. You should be ok as long as you have gauges to monitor everything.
USNavy2012 (01-14-2013)
Old 01-14-2013, 05:15 PM
USNavy2012's Avatar
Naw man, its 100% stock. I bought it about 2 weeks ago.
