Help adjusting 3k GSK
Old 02-02-2013, 02:29 AM
The_Master's Avatar
Default Help adjusting 3k GSK
Hi all,
I just finished installing a 3/4k GSK kit from pacbrake. I installed it as a 3k kit with the inside spring left out.
I measured my stock spring tension-distance and set the new to the same with 0.075".
After install idle was very high, ~1200RPM. I went back in and loosened them about 3/4turn, now idle is down to ~1000RPM free and 800RPM in park, this is still a lot higher than it used to be.
I figure that I need to just go back in and loosen them up some more. Also driving does not feel improved at all. I have less power and can not notice if there is any RPM difference. I used to see ~19PSI WOT @2000RPM and now I see barely 15.
Note: to install I went through the top of the AFC housing. I marked position for the plate and everything is reinstalled as close as possible to the original.
Is there a trick or something I am missing? My first impressions with a 3k GSK are not very good compared to stocker.
Thoughts?
*Edit*
Stock there were 4 governor springs. I removed the 3 smallest springs and their respective seats. I was not able to find any shims on either side for the small springs. There were shims for the larger springs, but the instructions said not to remove those. I reinstalled 2 new springs and the new seats.
Old 02-02-2013, 11:02 AM
turbo2332's Avatar
sounds like you might have already had a gov spring kit in there. tighten them back down about 5 clicks per side and adjust the idle down via the idle adjustment screw on the back of the pump.
Old 02-02-2013, 04:39 PM
The_Master's Avatar
How do I know if I had a governor spring kit installed?
My power seemed to top off @ about 2200 RPM before. I could free rev it a little higher, but I was never able to get much power above that. I was hoping to just prolong the power curve through ~2800RPM before the governor started defueling..
Ok, so I adjusted the idle screw and now the idle is proper, about 750 in park.
I tried sliding the AFC housing full forward and I did not like the outcome. I tried sliding it full aft and everything seems much better. However, max boost seems to be ~15PSI (boot fitting capped shut) and no smoke (very clean). I then adjusted the star wheel to full forward to attempt to build more boost and it *may* have helped a little but the difference is not that noticeable. The truck drives fine now, but seems to have a little more power down low and a little less in the top end (15PSI vs 19PSI). I still need to play with the smoke screw a little to limit the pre-boost fuel, but that is also accomplished with one's foot for the time being.
I am a little confused.
What is the adjustment to build more boost/fuel-more in the higher RPM's?
*edit* the GSK kit seems to let it free-rev up through 3k without issues, but I have not pushed it more than that without valve springs.
Old 03-03-2013, 10:26 PM
The_Master's Avatar
Ok Everyone, Just to wrap this thread up. I loosened the GSK spring tension a little and then adjusted the idle screw down to about 750RPM an everything is running great.
I also adjusted the AFC & moved the torque plate & AFC housing forward.
The only problem is I can slip the torque converter now, so I have to use a little right foot control.
