07.5 Smarty & Delete problems..
I have a smarty set on level 7 with full deletes and i still get CEL with 3 codes one is unknown code, 1 is something like turbocharger boost sensor voltage high, and 1 is like EGR temp sensor too high/ or high voltage. Sorry i cant remember the exact codes.. also my overhead periodically shows catalyst full service reqd.. and it is a dog now almost like limp mode... i dont get it.. runs normal till it starts to boost up seems like.. kinda either boost or rpm relevant you know.. thanks for any help please...
Well look at the numbers when u first plug the smarty in at the end should say me if not let me know and ill send you some files cause u have to run the me files and with the codes your throwing sounds like your prolly running the wrong tuning that might have helped cause your turbo to crap out
