very odd problem
Old 02-08-2013, 09:05 AM
Jbrown9357's Avatar
Default very odd problem
i have a 99 cummins and when it sits for a day the batteries are grave yard dead. also when the batteries are good it seems to not get fuel (it just turns over) but if i hook a battery carger up it will fire right up. just replaced fuel pump and on my fuel presure gauge i am reading normal (15 psi) until i go to fire then it drops to 1 psi i am thinking injection pump. anybody else have any ideas?
Old 02-08-2013, 04:12 PM
Im thinking low side restriction
but the batterys are first issue, need solid CCA before anything else can be diagnosed
are your batterys in good state of health and have a parasitic draw or are they just bad?
one bad battery can take out the other so test them both carbon pile test or a load tester w/e is available to you
min cranking psi should be 7psi , clean filter and lines that are not kinked or restricted
does the engine run? after boosted?
with what you have said so far this sounds like a low side supply issue
good luck
scott
Old 02-08-2013, 05:32 PM
Bryce's Avatar
The lift pump does not run while cranking so you will have low psi while starting. As long as psi is normal right after it starts your good.
Old 02-08-2013, 05:45 PM
ugg , bryce is 100% correct, I meant running psi not cranking psi, lift pump shuts down during starter engage sry for the misinformation
but im still not convinced of a pump issue yet
burndiesel
10
02-07-2023 01:15 AM
Jake9473
07-22-2018 08:19 AM
jeremy01995
09-14-2015 06:34 PM
moparman70
07-30-2015 12:38 AM
Cutlass26
03-22-2015 05:46 PM
Quick Reply: very odd problem
