1991 6.2l coolant leak
Old 03-02-2013, 10:23 AM
scrappiron68's Avatar
Default 1991 6.2l coolant leak
i just put new head gaskets on this '91 chevy 6.2l and now its leaking coolant from the back driver side of the block. where could the coolant be coming from.
Old 03-02-2013, 04:52 PM
racer55's Avatar
The rear of the heads have coolant passage coverplates-could be leaking from one of them or their studs?
Glow relay is often mounted to a rear stud in that area and would have needed some pipe sealer when re-installed.
Old 03-03-2013, 09:43 PM
MontanaTechPetroleum's Avatar
My 6.5 leaked from the block heater, caused by it shorting out. When I put a lower hose heater on it, I used some of that Bars stop leak powder and it doesn't leak antifreeze now, motor oil and power steering completely different story however. Might try it, its 1.62 at walmart, but you need about 3-4 bars of it, but it worked pretty good. If its a big leak, might not try it.
Old 03-06-2013, 10:58 PM
guy who worked on it after i left didn't tighten the cover plates. all good
IHdude
Chevy/GMC Duramax 01-04 LB7
07-12-2015 11:14 PM
throttleup22
05-02-2015 02:04 PM
Mike0885
02-28-2015 03:16 PM
merdth6
11-20-2014 08:01 PM
dieseldummy
6.2L & 6.5L Performance
10-01-2014 07:51 AM
Quick Reply: 1991 6.2l coolant leak
