help trans issue!!
Old 03-02-2013, 11:45 AM
1990CTD's Avatar
Default help trans issue!!
Okay I've got, well actually my dad has a 1998 dodge cummins 2wd auto. All stock besides some fuel turned up. When we drive it, if it is on a strain or turning or in you floor it, it fells like something is popping up and rattling on the floor. My old first Gen did it but mine was just mounts. I looked under and got a prybar but nothing loose. Idk if it is the trans slipping or what. But the floor aggressively shakes when you gun it. But its like a small constant rattling when its warmed up. Any ideas???
Old 03-02-2013, 03:13 PM
weerd..
would need to get this on a rack with the wheels off the ground and see it in action
this might be a longshot but check your front drive shaft cardan joint and u joints
actually if any drive shaft has a problem the noise and or vibration can transfer pretty good to the cab floor
verify your front drive shaft is not locked in 2wd and check the joints
please update , this sounds like a interesting diagnosis
good luck
scott
Old 03-03-2013, 10:30 AM
1990CTD's Avatar
So I should put a jack under the rear end and try it? And there is no grant drive shaft? Its a 2wd.
Old 03-03-2013, 01:08 PM
turbo2332's Avatar
i would check u-joints and the carrier bearing if it is an extend id cab.
Jake9473
07-22-2018 08:19 AM
Rabbitjbu
07-28-2015 06:03 PM
cementhead
11-16-2014 02:58 AM
pv89sj
10-12-2014 02:45 PM
Pyrohigh
10-11-2014 07:59 AM
Quick Reply: help trans issue!!
