Egr Delete Question
Old 03-10-2013, 05:17 PM
skirk55's Avatar
Default Egr Delete Question
I am waiting for my Smarty67Jr Me that is in the mail. Everyone told me that the Smarty will turn off the egr. My question is can I remove the egr with my Smarty. I can do the Dpf delete with no problem but the Smarty has me not feeling easy. I am low tech!
Old 03-10-2013, 05:51 PM
Loghomeman's Avatar
You will be fine with the smarty if you have the ME programing. You can do the egr/cooler delete,you will need a kit or make your own block off plates. I uased a sinister egr/cooler delete and I have the smarty j67 with ME ans everything works great no codes and no defuel. I also have the dpf deleted.
Old 03-10-2013, 08:12 PM
coors_man_2005's Avatar
^^this
Old 03-11-2013, 12:41 AM
Mikes3500's Avatar
Use the sinister egr/cooler w/bypass delete, if egr is shut off you can take it out.
Old 03-11-2013, 07:33 PM
skirk55's Avatar
I have seen a breather uesd with the egr delete. Anyone use that?
Old 03-11-2013, 08:04 PM
you talkin that comes off the valve cover?
Old 03-12-2013, 06:30 PM
skirk55's Avatar
Yes that is it!
Old 03-12-2013, 06:50 PM
that is the crank case filter delete. if you look through my threads. i have one on the how to do it and benefits.
Old 03-13-2013, 12:12 AM
Mikes3500's Avatar
I used the GDP one it just is a elbo and filter w/clamps, also has a plug to cover where ccv went into turbo. I used it instead of just a hose that drained on the ground,didn't want oil on my driveway.
Old 03-13-2013, 07:01 PM
just go to the parts stor for less half the cost of the major brands
willyam
Price Quote - Request A Price
05-19-2015 10:20 AM
Bighouse
04-09-2015 06:51 PM
tbreddiesel
Thoroughbred Diesel
01-12-2015 02:23 PM
Shmeldon22
Ford Powerstroke 08-10 6.4L
12-14-2014 11:22 PM
Quick Reply: Egr Delete Question
