head bolts/studs
Old 03-11-2013, 05:42 AM
fireman-1781's Avatar
Default head bolts/studs
Does anybody know the difference between ARP2000 head studs and the custom age head studs? Is there a big enough difference to justify the cost difference?
Old 04-01-2013, 06:49 PM
BBD Tech Support's Avatar
ARP2000 Head Studs are 220,000 psi tensile strength
ARP custom Age Head Studs are 260,000 psi tensile strength. (For higher HP)
And price is the other difference
Old 05-02-2013, 01:40 PM
Duramax_lly's Avatar
Have to tap the block for the bigger studs I'm pretty sure.
Old 05-02-2013, 02:34 PM
MillerBoyzDiesel's Avatar
Theyre not bigger just different material. If you have an unlimited budget the customs will add some extra insurance but, Ive seen the regular 625's hold up just fine in compound setups and other various high horsepower applications.
Old 05-03-2013, 01:24 AM
2004LB7's Avatar
I believe your are just chasing the bottom few threads to take advantage of them. This would be done with a bottom tap as GM uses a taper tap and the last few are not complete
TheMacster
5.9L 24V Performance
04-14-2015 07:01 PM
klein444
6.2L & 6.5L Performance
04-14-2015 09:04 AM
Vmason
Ford Powerstroke 99-03 7.3L
01-21-2015 11:33 PM
Adam65
01-09-2015 11:50 PM
10-31-2014 08:10 AM
Quick Reply: head bolts/studs
