Chevy/GMC Duramax 07.5 -10 LMM Discussion of Chevy and GMC Trucks with LMM Duramax Turbo Diesel Engines
Just picked up 2007.7 lmm duramax need pointers
Old 03-13-2013, 11:11 PM
bigtony55's Avatar
Default Just picked up 2007.7 lmm duramax need pointers
Hi guys just picked up a gmc 3500 dually with a duramax in it (trucks not here yet should be here monday) was told its bone stock looking to do some upgrades better muffler for sound for sure possibly turbo back system but what muffler if turbo back not needed and what size it is it 4" or 5" also id like to get the best plug and play adjustable(setting options) tuner available i want power and milage and intake system if needed i also hear of egr and or other block offs? can someone give me some cut and dry awnsers if thats possible LOL i know there is alot of variables Thanks
Old 03-14-2013, 10:41 AM
MillerBoyzDiesel's Avatar
If youre gona stay legal youll want to look at dpf back exhausts. If you get rid of egr youll need to get rid of dpf as well. Look for efi live tunes and find a shop that dont mind doing delete tunes. If you are looking for multiple on the fly adjustable tunes you can go with efi and a dsp5 switch. Epa has got involved pretty heavy so a plug and play setup with delete tunes is hard to find and or very expensive.
Old 03-15-2013, 12:00 PM
bigtony55's Avatar
Thanks but what is the dpf?
Old 03-15-2013, 12:33 PM
diesel particulate filter its in your exhaust system and catches soot it fills up over time and does a self cleaning cycle called a regeneration cycle. With the egr system disabled your truck will not run a regen cycle and the dpf will clog up. Thats why it needs to be removed if doing an egr delete.
Old 04-30-2013, 03:08 AM
LMMDrillDaddy's Avatar
Ive got the Quadzilla Stealth 2 in my lmm dually and i honestly wouldnt recommend it. Its not a bad programmer but it doesnt really help with fuel mileage as much as you would expect. And if your looking to add power too, then its not very good in that since either. Dont get me wrong, If you crank it up, it will get up and go but with all the smoke, there wont be a road behind you anymore. I tuned mine up to the 135 tune and couldn't accelerate 5 mph without blacking out a 4 lane highway. I keep it on the 90 HP tune just because it doesnt throw as much smoke and the fuel mileage is better there. Cant wait to get EFI If you get EFI right off the bat, they can make you custom tunes that wont hurt your trans if you decide to get squirly with it. Its safer for your truck and will perform better. Plus you dont have to stop and do a 5 minute process to change the tune. Also, mine freezes up all the time and i have to start the whole process over again. Just my .02
Old 05-05-2013, 10:32 PM
joshs1's Avatar
I would honestly go with the Efi Live tuning. i run a four inch back straight pipe. i get amazing fuel mileage driving 55 i can average about 22 mpg and running 75 can average 18.5 and around 16 pulling a 7,00 pound trailer. An like LMMDrillDaddy said they custom build tunes for your truck and keep everything safe for your tranny and if you built your tranny you can add more power.
Old 05-10-2013, 05:20 AM
BBD Tech Support's Avatar
alot of variables is a true statement. To many to list
Don't forget a Tie Rod Kit or Tie Rod Sleeves if it's 4x4
Old 05-11-2013, 01:11 AM
joshs1's Avatar
Speaking of the Tie rod sleeves. i have been looking for those for a while now and cant seem to find any good info on it or anyone that carries them.
Old 05-13-2013, 08:25 AM
There are tons of them out there. Try xtreme diesel, thoroughbred diesel, ppe, merchant automotive, alligator performance.
speedracer565
05-24-2015 09:04 PM
Renowest48
12-14-2014 08:36 PM
Quick Reply: Just picked up 2007.7 lmm duramax need pointers
