Strange Noise
Old 03-17-2013, 12:29 AM
cummin^strokin's Avatar
Default Strange Noise
Hey guys, I drive an early '04 3500 with a turbo back 4" exhaust with a flow through muffler. Everything else is stock. Recently I have had a weird drone when I am accelerating that occurs in the range of 23-27 mph for a second or two and also when I am decelerating at or around the same speed range. The noise seems to be originating right over the center console area. I am currently on the road and plan on throwing it on the lift once I am back in the shop. Just wondering if anyone has experienced this or has an idea as to what could cause this....
-Cheers
Old 03-18-2013, 01:25 AM
97cummins's Avatar
It could be a loose exhaust part
Old 03-19-2013, 10:27 PM
The weird thing is that I only hear the drone at 23-27 mph and after inspecting it today I have eliminated all of the u-joints on the front and rear drive shafts. I am thinking it must be a bearing inside the transfercase or something slipping in the trans...
Old 03-20-2013, 03:42 PM
CHEMMINS's Avatar
Carrier bearing in rear driveshaft? Could be transmitting the noise through the transmission.
Old 04-02-2013, 11:50 PM
Well I crawled under the truck and all of the u-joints on the driveshafts, both front and rear, are all tight. I'm thinking it has to be a bearing. Weird thing is though the past couple days it has warmed up and I cannot get the truck to make the noise now! Of course...
Max713
04-17-2015 05:41 PM
Boatman
03-20-2015 10:00 AM
Dak_summers
01-22-2015 08:45 PM
2FordStrokers
Ford Powerstroke 99-03 7.3L
01-11-2015 09:40 PM
dutchsupreme
12-18-2014 01:44 PM
Quick Reply: Strange Noise
