CCd overhead with a no start condition
Old 03-17-2013, 01:11 AM
2001cummins24v's Avatar
Default CCd overhead with a no start condition
Yesterday I changed my oil, steering box, and shocks. After I made my final checks I went to start the truck but it wouldn't start. The overhead reads CCd ( Chrysler collision detection), the truck has more than 3/4 of a tank but reads empty, the mileage flashes while the key is on, when the key is first turned on the priming pump does not cycle. I have checked the fuses and I went over the areas that wires could have been unplugged but found nothing. I am at a loss on this one and Any help would be great!
Old 03-17-2013, 08:27 AM
Mopar1973Man's Avatar
CCD Network errors... More information in the link.
Mopar1973Man's Dodge Cummins Articles - CCD (Chrysler Collision Detection) Data Bus
I What I typically suggest is to disconnect all the optional stuff like the radio, central timer, etc. one at a time and see which device is got the problem. Once you find the device then the CCD network voltages should return to 2.49 and 2.51 on the 2 CCD pins of the OBDII port.
Old 03-17-2013, 01:22 PM
So I need to dis connect the accessories one at a time and check voltage on pin 3 and 11 of the obd port at the bottom of the dash? Thank you for your time and help!
Well I haven't had any luck I have been looking around and some people are saying that the clock switch could be the problem and so are saying some thing about a fuel shut off? Thoughts and opinions would be great.
Thank you
Last edited by 2001cummins24v; 03-17-2013 at 01:22 PM. Reason: Automerged Doublepost
Cavnar
09-09-2015 07:18 PM
cjgregory
03-31-2015 01:45 PM
IGOU
03-08-2015 04:25 PM
ronstop
02-26-2015 09:48 AM
carid
Diesel Bombers Sponsors
11-18-2014 06:49 AM
Quick Reply: CCd overhead with a no start condition
