turbo whistle
Old 03-26-2013, 05:54 PM
jimrd's Avatar
Default turbo whistle
my turbo is whistling
thought the top turbo hose had a hole in it
i installed new hose and the whistle is still there
thinking about up grading the turbo to a larger one
the truck is basically stock
What is the noise??
i was looking on innovative diesal web site
looked at the one for 1400
siad faster spool up over stock
Looking for a little more performance and gas milage
thanks
Jim
Old 03-27-2013, 05:59 PM
hp_pants's Avatar
the turbo is toast: if you have a leak anywhere before or after a turbo, it side loads the bearings and wears them out.
Old 04-01-2013, 03:44 PM
jimrd's Avatar
so should i get a bigger turbo from innovative diesel??
since my beasrings are starting to go?
will there be a difference?
1400 plus shipping for new Garettt turbo
Old 04-01-2013, 04:10 PM
hp_pants's Avatar
There will be a difference. I wouldn't spend $1400, you can put a new cartridge in it for less if you aren't afraid of taking apart and cleaning the variable vane system. It's pretty easy and it's a good way to save $500
Old 04-01-2013, 07:12 PM
BBD Tech Support's Avatar
bump
Old 04-04-2013, 01:20 PM
jimrd's Avatar
should i buy i larger turbo ??
or can you get a rebuild kit
bearings
Can i do my self
Old 04-04-2013, 02:27 PM
HeavyAssault's Avatar
For a stock truck and stock turbo works just fine. I say rebuild and be happy. Save the bucks for other mods.
Old 04-05-2013, 09:56 AM
jimrd's Avatar
can i rebuild the turbo my self
is there a repair kit from ford ?
Old 04-05-2013, 11:16 AM
Garret Stopped offering the rebuild kits
Old 04-14-2013, 10:22 PM
ih8yourface2's Avatar
go with a twin turbo upgrade for 3500$
just kidding you could but yeah it sounds like your barrings might be shot careful that ur head gaskets are wearing or almost blown my barrings started to go right before that happened cause your turbo is working harder burns them out. also if u need a turbo go to a junk yard like a pull apart grab a stock one save a couple hundred dollars. just a suggestion.
Quick Reply: turbo whistle
