12v misfiring after DV leak fix?
Old 05-11-2013, 08:05 PM
liv4sno1's Avatar
Default 12v misfiring after DV leak fix?
So i finally got my DV socket, which i ordered to fix the two leaking DVs. Took DVs out and replaced small o-rings, but didnt change the green o-ring. threw everything back together,fired it up and its noticeablly misfiring. I cracked the lines to find out which cyl it was, second one back from front of motor.dissasembled and cleaned the injector to make sure it wasnt grit sucked through from when i opened the DV up. everything back together. Still misfiring.no black smoke at idle, idle drops a little and smooths out when i crack misfiring line. Any ideas? maybe i put something in wrong?
just a note too, it misfires from idle to wide open
Old 05-13-2013, 04:13 PM
1993firstgennewbie's Avatar
What is a DV
Delivery valves?
Last edited by 1993firstgennewbie; 05-13-2013 at 04:13 PM. Reason: Automerged Doublepost
Old 05-15-2013, 04:14 AM
97cummins's Avatar
Originally Posted by 1993firstgennewbie
What is a DV
Delivery valves?
yup
cutthroatxxx
The Bomb Shelter
08-06-2015 03:08 AM
IHdude
Chevy/GMC Duramax 01-04 LB7
07-12-2015 11:14 PM
InheritedDiesel
06-03-2015 09:39 PM
ItsAChummins
05-15-2015 05:02 PM
ash23k
12-30-2014 08:31 PM
Quick Reply: 12v misfiring after DV leak fix?
