phatshaft 62 turbo
Old 05-21-2013, 01:10 PM
cummins Pride's Avatar
Default phatshaft 62 turbo
i would like a turbo that can get good boost levels if i need to but would like to keep stock head bolts for now has new head with brand new bolts i saw some things on the phatshaft 62 turbo being good for what im looking for or a ats 3000 what do you guys think my mods are in my sig
noone can help
Last edited by cummins Pride; 05-21-2013 at 01:10 PM. Reason: Automerged Doublepost
Old 05-21-2013, 04:32 PM
daveO's Avatar
I think the phatshaft 62 would be a good choice. From what I've been hearing about ATS's warranty issues, I would stay away from them.
Old 05-21-2013, 06:22 PM
ng102310's Avatar
ATS = warranty problems... had a friend go through that once. I swore I would never buy anything purple
Old 05-21-2013, 07:02 PM
cummin_un_glued's Avatar
FormerVendor
I wouldn't go with the 62 unless your planning larger injectors int he future I would do a S300G
Old 05-22-2013, 09:47 AM
do you mean larger than my 370 marines i have right now
Old 05-23-2013, 04:41 PM
FormerVendor
Yes
Sent with a Droid RAZR in one hand and 14,000 volts in the other.
Old 05-25-2013, 09:59 AM
jkidd's Avatar
5x.012 is a good match for the 62mm. the ats3000 is closer to the s300g 57mm and is kind of expensive for not being a wastegated turbo.
5x.013 and a 63mm is a good match too.
with your marine 370 you will want to keep timing under 16.5* so you do not spray out of the bowl
Old 06-14-2013, 08:50 PM
95taylor331's Avatar
I would go with the 62/65/12 with the mods you have , I think with a 71/14 you would have a hard time spooling it, you can also turn the boost elbow down on it if you start exceeding 35-40psi, just my 0.02
Old 06-14-2013, 11:59 PM
4x4manonbroke's Avatar
I' m looking into the S300GX from airworks .. $1080.00 .... will support upto 400 hp .. they unfortunatly could not give the exact sizes and or dimentions but the airworks web page does have the map for these turbo's .... fyi ...
Old 06-15-2013, 12:22 AM
jkidd's Avatar
It is the same thing as a super B turbo but it does not have the adjustable wastegatge and you may need to adjust the actuator rod by bending it so it will clear the oil drain line.
specs are 57/65/14 flows 61lbs. great for 400hp. The BD one is better as it has some upgrades to it.
avatardvr
18
08-08-2019 12:38 AM
Hogridenfool
11-20-2017 04:37 PM
n2brk
02-21-2015 09:05 AM
tumble72
8
11-27-2014 10:31 PM
GreenDieselF
10-20-2014 02:05 PM
Quick Reply: phatshaft 62 turbo
