factory lift pump ?
Old 06-20-2013, 08:04 AM
tnduramax05's Avatar
Default factory lift pump ?
i recently read an article on the web about the cab/chassis trucks have a factory frame rail mounted lift pump i am just curious to know wether the 2500hd and 3500hd trucks have the same wiring harness that includes the plug for this or if it would even be worth the time to install one of these just for the time being until i can do the fass setup cause i can purchase one of the replacement pumps for cab/chassis relatively cheap thanks for you guys input
Old 08-16-2013, 11:28 AM
sessions's Avatar
My understanding is no for the wiring plug option. The Fass 150g set up for this truck uses a constant power source to the fuse box/battery and a secondary power source that is tied into a key activated power fuse. I would think that Fass would know about an easier quick plug if there was one available. Hope this helps!
landon025
09-08-2015 09:21 PM
Renteria1217
04-16-2015 11:38 PM
klein444
02-21-2015 10:33 AM
moneypitk5
02-12-2015 11:01 AM
greenbomb
01-23-2015 10:36 PM
Quick Reply: factory lift pump ?
