Lift kit?
Old 06-20-2013, 08:21 PM
03CumminsNoob's Avatar
Default Lift kit?
I'm looking at getting a bigger lift for my 03 Cummins. I currently have a 2.5" rough country leveling kit with the blocks under springs in back. This was on truck when I got it and also has 35"-12.5-17's Kelly safari's. Truck handles fine now and 35's fill wheel wells good but do rub some on a lock to lock turn. I'm wonder what kit is best for the price and ride quality. Have heard some good things about BDS 8" long arm kit for about 2k. Also planning on running 37" tires, are there many choices and what do they run in cost? Leveling kit just doesn't seem like enough anymore but what will I sacrifice going 8" and 37's?
Last edited by 03CumminsNoob; 06-20-2013 at 08:21 PM. Reason: Automerged Doublepost
Old 06-20-2013, 10:09 PM
CHEMMINS's Avatar
Stock wheels can run 37's. Just get some thuren arms.....it'll push the axle where it should be. Also get an adjustable trac bar to relocate the axle back to center.
Old 06-21-2013, 07:06 PM
I have eagle alloy wheels and most kits come with the adj trac bar. No one else has a lift that can give me some input? Should I move this to another section cus I usually get some response.
Old 06-22-2013, 09:30 AM
ColinHartwick's Avatar
If you want 37" i'd say go with a 6" kit a buddy of mine just put 6" pro comp lift in his Ram and hasn't had a single problem with the truck in any aspect of the lift.
Old 10-22-2013, 06:46 AM
WestTexasOutlaw's Avatar
i have an 06 2500 with 6in SUPERLIFT!!!! running 37s, smooth ride and great off road!!!!
Old 10-22-2013, 09:21 PM
codyawise's Avatar
I bought my truck with a 6" lift on it and 37s not sure what for brand it is though unfortunately. Only ever rub if I'm turning and hit a bump just hit the dumb little plastic piece under the bumper
Old 10-25-2013, 02:14 PM
12vonshine's Avatar
6 inch lift will work fine to clear 37s (may have a little tire rub), just need to pick a company. I like CARLI products but comes with a price. I am sure any of the other big name lifts are good.
Old 10-25-2013, 02:25 PM
bigbull7.3's Avatar
Old 12-08-2013, 07:33 PM
FlyingDutcman's Avatar
a buddy of mine has 2.5" rough country coil spacers with 37/12.5/17 dick cepek fun countrys, only rubs on full lock turning right. Synergy makes the starter kit for 37" tires, and from what ive heard its a reasonably priced quality kit.
that BDS kit is worth every penny, but it isn't a 2k kit once you have played with all there options!
04-29-2015 08:20 AM
slowstroke
For Sale
03-27-2015 05:19 PM
Ruddedawg5.9
02-22-2015 10:54 PM
turbodiesel123
10-24-2014 10:27 PM
JJ Diesel
10-06-2014 11:21 PM
Quick Reply: Lift kit?
