Ford Truck and Powerstroke Turbo Diesel Forum Discussion of General Topics related to All Ford Trucks as well as the Diesels in them
EGR Block-Off Kit - 6.0L Power Stroke
Old 04-05-2008, 01:00 AM
Diesel Bombers's Avatar
Staff Reporter
Information EGR Block-Off Kit - 6.0L Power Stroke
In the diesel performance world, Ford 6.0L Power Stroke engines have a bad reputation for blowing head gaskets and sticking EGR valves when owners modify them. There are a number of reasons why people have problems with their modified 6.0Ls, but one of the main culprits is the exhaust gas recirculation (EGR) system.
WHAT IS EGR?
Exhaust gas recirculation (EGR) is a system of plumbing and valves on a gasoline or diesel engine that sends burnt exhaust from the engine back into the intake side of the motor to be consumed again. Theoretically, because EGR has already been combusted once, it has no oxygen or fuel in it to be burned again.
Engine designers use EGR as a tool to reduce the amount of nitrogen oxides (NOX) emissions that an engine produces. Nitrogen oxides come from high-combustion chamber temperatures. Yet, when EGR is introduced into the engine, it tends to displace the amount of oxygen available to burn. This lowers the combustion chamber temperatures and the amount of NOX coming out of the tailpipe.
EGR NEEDS TO BE COOLED
For all intents and purposes, EGR is exhaust gas, exactly what you'd expect to see and smell coming out of your truck's exhaust system. It comes out of the engine hot. So before it is routed back into the intake, it is generally cooled with a heat exchanger connected to the engine's cooling system. Keep in mind that if the engine has been modified, the exhaust exiting the engine may be hotter than it should be. Plus, if there is any unburned fuel or oil in the exhaust, it'll wind up in the EGR system too.
6.0L EGR PROBLEMS
The problem is that Ford didn't design its EGR system to handle the extra heat and unburned fuel that find their way into the EGR system when these engines are modified. The EGR cooler can even cause the engine to run hot as the super-heated exhaust from the EGR overwhelms the EGR cooler and causes the engine coolant circulating around it to boil. Boiling coolant isn't good for the engine. Not to say this is the only cause for 6.0L head gasket failure, but it is certainly a common one.
THE COMPETITION VEHICLE SOLUTION
With this in mind, we headed over to Liberator Performance to talk to Shawn Liberator, who has a kit to remove the EGR cooler, and EGR in general on vehicles that will not be used on the street. The beautiful part of this kit is that it is a direct bolt-in replacement for the EGR cooler. The installation of the EGR delete kit isn't for the novice mechanic, but if you take your time and have pretty good mechanical knowledge, it is completely doable. This kit takes a professional between six to eight hours to install, so be prepared to spend some time on this project. Unfortunately, this modification is not for street-legal use on emissions-controlled vehicles.
DRIVING IMPRESSIONS
This is an off-road only kit, so it's not to be used on 6.0L trucks that will see any time on the street. This is a very comprehensive kit where everything fits nicely and works well together. However, we did run into a problem during installation. When we removed the EGR cooler, we pushed back the y-pipe a little too far, which caused the expansion joint in the y-pipe to crack. Once we replaced the y-pipe, we then took the truck out and did some testing.
In most instances, the factory EGR system works during low to medium throttle and stops on full-throttle/high-demand driving. The difference without the EGR was noticed almost instantly as we came to our first hill. We were driving about 70 miles per hour between 1,800 to 2,000 rpm, and the truck lugged a little to get up the hill. But it didn't downshift. Normally, the truck would drop a gear to make it up this hill. In addition to having more low-end power, the exhaust temperatures dropped between 50 to 150 degrees.
Another wonderful advantage of this upgrade is the lack of soot entering into our intake. Typically, soot builds up on the intake radiuses, which causes turbulence and eventually a reduction in horsepower. The soot also ends up getting into the engine oil. As the soot particles mix with the engine oil and eventually find their way through the engine oiling system, the tiny little particles cause the engine bearing to wear faster.
After we were done with our off-road testing, we were pleased to note that our 6.0L test truck never missed a beat. Best of all, we can now run the truck hard without the worry of boiling coolant or blowing headgaskets.
Photo Gallery: EGR Block-Off Kit - Diesel Tech - Diesel Power Magazine
Read More | Digg It | Add to del.icio.us
More...
The following 3 users liked this post by Diesel Bombers:
HVACguy (04-09-2008), obcar (06-19-2009), todd (11-30-2008)
Old 04-09-2008, 11:40 AM
RTL Garage's Avatar
Great Article!
Old 08-03-2008, 09:14 AM
bigD12's Avatar
can anyone tell me where to get the egr block off kit.
bigd12
can any one tell me where they sell the block off kit for the egr cooler.\
bigd12
Old 08-03-2008, 06:24 PM
BLACK_06POWERSTROKE's Avatar
elitedieseleng.com is where i would start for anything on a 6.0
they have 3 or 4 options to choose from on the egr bypass systems
Last edited by BLACK_06POWERSTROKE; 08-03-2008 at 06:24 PM. Reason: Automerged Doublepost
Old 08-27-2008, 04:15 PM
deerplow's Avatar
Thanks to all for the info. Just had my head plate gasket replaced and asked the mechanic about a rumor I heard that if you wanted head studs installed they would do it while the heads were off and it would not void any warranties but you have to buy them and take them in.
Old 09-22-2008, 09:30 PM
smokin_h's Avatar
thx for the great info!!!
Old 04-21-2011, 02:40 PM
ecodiesel's Avatar
cool 6.0 venting with egr
you have to be careful when you screw with the egr system, because it is also part of crankcase vent. if it is insf. the oil drain in turbo will not drain and will overfill , because it is being serviced with 70lbs of oil pressure. when it doesnt drain it will cause oil out the back of turbo , so black smoke in exhaust , oil out the front of turbo will fill your cylinders and intercooler with oil. best case you will lose compression ,worst case the oil mixes with fuel being supplied normally and you could go virial and it may self destruct. it almost happen to me. luckily i stopped as soon as i got the smoke. all im saying in effort to elim. one prob you dont create another. ecodiesel. does anyone bypass egr and not get ck engine lite? and cc venting
Old 04-21-2011, 08:58 PM
LORDDiESEL's Avatar
better do some more homework. They have nothing to do with each other.
Old 04-22-2011, 05:14 PM
Yeah not even close. The CCV goes right into the intake in front of the turbo so everyone with a 6.0 already has oil in the CAC tubes and intercooler.
03/04 trucks usually don't throw a check engine light with an egr deleted, but 05+ usually do. In both cases I've seen the opposite true, although very rarely. An SCT with custom tunes will get rid of the light.
Old 04-24-2011, 09:41 PM
BobbyCann's Avatar
Can you block off the EGR cooler with out removing the EGR valve so it doesn't throw a code that has to be reset.
Quick Reply: EGR Block-Off Kit - 6.0L Power Stroke
