Pulling Transmission
Old 07-17-2013, 02:50 PM
2005DFS's Avatar
Default Pulling Transmission
I am going to drop the transmission out of my truck to install a Goerend billet flex plate. I think the stock one is cracked and the cause of a noise I have been searching for awhile. While I have the transmission out is there any thing I should look for / inspect on the torque converter and the rest of the transmission. The transmission seems to be working just fine. I eventually want to install a Goerend built transmission, but budget does not allow for that at this time. Just looking for some insight on things I should do while it is out. Any help would be great.
Old 12-04-2013, 09:56 AM
Big5.9's Avatar
check everything you can, see if anything is cracked, looks like it has a defect anything along those lines, or if anything is loose as well.
Max713
04-17-2015 01:18 AM
02Stain
02-17-2015 10:21 PM
Tucker126
01-02-2015 08:09 AM
W350-4x4
11-12-2014 09:35 AM
TheDirtyDozen
10-01-2014 10:09 AM
Quick Reply: Pulling Transmission
