A/C fix up...
Old 09-02-2013, 02:43 PM
Cree's Avatar
Default A/C fix up...
So I am still running R12 in my 91.5 and its finally getting to the cool not cold stages. Everything works correctly, and I have never had to add anything or do anything exciting to it. A friend of mine that moonlights as a mechanic from his full time job as a mechanic says we can dig up some R12 and toss it in or he can convert it to 134. I know there are a bunch of posts on this conversion, for, against, and otherwise, and I've tried to read as many as I could find, but, realistically, when we recharge or convert, are there any "wear" items that are worth replacing while we have it apart? If I read ten posts, I get ten opinions, but for those of you that have done some A/C work, I'd appreciate your two cents. I only want to do this once.
Thanks-
Cree
Old 09-02-2013, 06:47 PM
Joel Steven's Avatar
If it ain't broke don't fix it. That fact that it still works at all tells you that it is not leaking too bad. It is normal to loose a little bit of refridgerant over time. Just throw in a pound or 2 of r12 and it should work fine again.
R12 is the best, especially in a system that is designed for r12.
That's what I do to my truck. In the 10 years I've owned it, I've never pulled the AC down or repaired it, just add a pound about every 2 or 3 years. Cheap, easy, effective.
Old 09-06-2013, 06:12 PM
CUMMINStagetcha19's Avatar
The truck only holds 38 oz if its still cooling its not that low. I would keep adding if you can find r 12. If you convert, you will put 70% of r12 capacity because r134 chemical makeup is different than 12. That being said the ac also won't perform as well. Of all the tractors I've converted from 12 to 134 they all are better than no ac but not as good as the original 12 system....
Cree (09-06-2013)
Old 09-06-2013, 11:35 PM
Cree's Avatar
...and for those of you who need R12, you can get it on Ebay. Most of the sellers only require that you electronically sign a statement that you are going to have it installed by a licensed shop, you have the EPA certificate 609, or you are going to resell it to a licensed installer. A can at $35 including shipping is sure not what we used to pay, but all the drama of the changeover to 134 and the guesswork of the charge and the cleanup/changeover from mineral oil, as well as going to barrier hoses, etc. Since I am dealing with a known working system that has never been changed, some leakage is expected and if anything, it is working better this summer than last (cleaned evap and condensor) so I'm rolling the dice. I know I'll have to get there sooner or later, but the front brakes are eating my budget this next month, and in a few months, we'll be off the A/C for the year. For those of you who aren't sure why your truck doesn't cool, I would start with the basics of vacuum and clean, then shop for the refrigerant of choice. No sense in wasting this gold plated freon...
cutthroatxxx
The Bomb Shelter
08-06-2015 03:08 AM
Maclain Marsh
07-13-2015 06:23 PM
Jladanyi
07-04-2015 02:43 PM
CumminsCoalRoller24/7
05-05-2015 08:55 PM
JasonG.
Ford Powerstroke 08-10 6.4L
02-26-2015 08:51 PM
Quick Reply: A/C fix up...
