1994 7.3L IDI turbo
Old 09-05-2013, 03:05 AM
thefatman04's Avatar
Default 1994 7.3L IDI turbo
i got a 94 7.3L IDI w/turbo, and i was wondering what i need to make it stock again. i want to take the turbo off and sell it, but i need to know what parts i need to buy to replace it with. so can anyone help with this?
Old 09-05-2013, 09:58 PM
4x4manonbroke's Avatar
send me your turbo ... I'll send you my air cleaner
Old 09-06-2013, 04:40 PM
rjjp's Avatar
Why do you want to remove the turbo?
Old 09-14-2013, 03:58 PM
Because the turbo on it works, but with the way its setup its not really putting anything out any more Hp!!
Old 09-14-2013, 06:22 PM
well anything over 8 psi is gonna cause longivity issues due to the naturally high compression ratio ...... can run higher and some have .... but not for 500K like stock could.....
u can swap back to naturally asperated .... go to junk yard and get ur parts & take notes on how its set up W/out turbo ..... should be really simple to convert.... note: use big airfilters and large exhaust on these engines ... they love to briven hard all day... power normally comes in around 2-2500 rpm's .... i run mine to govenor all the time
Old 12-13-2013, 08:36 PM
ALWAYSREADYROB's Avatar
Mine only shows 4 lbs of boost...what gives ?
GarrettEvan
01-30-2016 05:39 PM
Devon7.3
09-27-2015 10:35 PM
mrmuckshifter
03-24-2015 01:48 PM
mrmuckshifter
03-24-2015 01:47 PM
schearer350
02-12-2015 12:27 AM
Quick Reply: 1994 7.3L IDI turbo
