Transmission HELP!
Old 09-22-2013, 12:27 AM
duramaxdave's Avatar
Default Transmission HELP!
So i am looking at buying an 03 Chevy 2500 but it is throwing a pressure sensor code from the trans. But the real issue is that it will only drive a few feet in drive then kick out of gear, but will drive in reverse. I want it and I am getting an amazing deal on it but please help.
up
Old 10-04-2013, 11:31 PM
2004LB7's Avatar
sounds like the pressure switch manifold (or more likely the NSBU switch - Neutral Safety Back Up) has gone kaput or a bad wire.
the NSBU is easy to replace and fairly cheep
more info: Question Allison 1000 Troubles?? - Chevy Truck Forum | GMC Truck Forum - GmFullsize.com
i would by the truck if the deal is good
Old 08-19-2014, 10:13 PM
abeey91's Avatar
Default tranny help.
I have a 03 LB7. With 101k miles. The truck is 2 wheel drive. It often won't come out of gear. The light indicator. Or linkage. Flashes and the message center reads. SHIFT RANGE INHIBITED?. Yesterday the truck took about 1/4 tp shift out of first. At a steady 2,200 rpm. Runs fine after that. Untill i shut it off and start it again. Where is this sensor located
Old 08-20-2014, 12:30 PM
2004LB7's Avatar
possibly the nsbu switch
also, check fluid level and filter. doesn't sound like a sensor to me
Max713
04-17-2015 01:18 AM
02Stain
02-17-2015 10:21 PM
SixSpeed
01-11-2015 01:41 AM
W350-4x4
11-12-2014 09:35 AM
TheDirtyDozen
10-01-2014 10:09 AM
Quick Reply: Transmission HELP!
