Blocker Plate for the EGR
Old 12-25-2013, 01:38 PM
Kooper's Avatar
Default Blocker Plate for the EGR
Hello Gents,
I have a 2004 6.6L LB7. 130,000miles and counting. No engine or transmission mods done.
I'm looking at getting an EGR Blocker Plate and was hoping to get some advice and questions answered. Any help is greatly appreciated.
#1 Does the EGR Blocker Plate throw any codes and/or the check engine light?
#2 If so do I need the Finger Stick mod or will a simple tuner fix the issue?
#3 If it does throw an engine code/check engine light will the truck still run normal or go into limp mode?
Again any help or advice is greatly appreciated!
Old 12-25-2013, 09:14 PM
gmcmanis's Avatar
Blocker plate will throw codes. EFI LIVE can shut it off without the blocker plate and it will run perfect. Blocker plate will only help when the boost hits over 20 psi and it causes the valve to kick open.
Old 01-01-2014, 03:10 AM
Kooper's Avatar
I'll be running over 20psi quite often.
Is it better to do the blocker plate or the complete delete?
Old 01-02-2014, 09:55 PM
gmcmanis's Avatar
blocker plate is suitable for more boost and smog cant see it
Old 01-15-2014, 11:53 AM
1959JD630's Avatar
LB7 Don't have an EGR. Duramax didn't install EGRs until 04.5 with the LLY. LB7's have no emissions
Old 01-15-2014, 12:56 PM
Kooper's Avatar
I'm surprised how many people say that it's very interesting.
Never the less though the truck is an LB7 and it does have emissions controls including an EGR.
Old 01-29-2014, 07:25 AM
Outlaw88's Avatar
Mine is a 2002 and it has an EGR. some LB7's starting in 2002 came with EGR if they were a California emissions vehicle.
Old 01-29-2014, 07:49 PM
Snowbound98's Avatar
Go with the blocker and finger stick if you don't wanna go to the complete delete. I ran a blocker and finger for a couple months with no issues. Have since upgraded to full delete. Also went to EFILive and highly recommend it. What a difference.
Old 03-03-2014, 06:16 PM
mmaranto's Avatar
There were lb7's that came with emission control on them. I read it was the lb7s that were built and being shipped into states that had smog control n all the regulations. California was a big one. I have an 03 lb7. No egr. A buddy of mine had an early 04 with an egr on it. He just did a full delete on it. Worked pretty good for him. But he ran it in the 1/4 mile more than on the road.
Old 03-03-2014, 09:06 PM
Outlaw88's Avatar
All Duramax engines are built here in the states. The factory is in Moraine, Ohio.
Quick Reply: Blocker Plate for the EGR
