HX35 Turbo Or Compressor Upgrade
Old 09-08-2008, 10:30 AM
C/PRD/'s Avatar
That's a 58mm hybrid
  #12
Old 09-08-2008, 07:00 PM
07Chassis's Avatar
Originally Posted by Diesel Dummy
More fuel........ thats the easy part!!!!!!!!!!!
Thats the best part, the smoke! Is grinding the afc lever worth while, and how much to grind? Im picking up my 3200 governor spring tommorow at a local supplier.
  #13
Old 09-08-2008, 07:24 PM
SHAMBO's Avatar
What is a HX35/HX40 Hybrid and how is it done, and what does it do for you?
  #14
Old 09-08-2008, 09:18 PM
welderboy250's Avatar
the hybrid is made using a 35 exhaust wheel and 40 compressor and of course the housings that go with them. if u got a 35 u just need the compressor wheel and compressor housing. it pushes a lot more air than the 35 and it bolts right on so its awesome
  #15
Old 12-24-2008, 09:51 PM
Oddfire's Avatar
So once more, what is the recommended mod/fuel level of an engine to be able to take advantage of a 35/40 hybrid?
  #16
Old 12-25-2008, 05:39 PM
RSWORDS's Avatar
And the backing plate.
Anything over stock.
  #17
Old 11-29-2011, 11:57 PM
jdbigblue12v's Avatar
digging up an old thread but i can get a complete hx35 with a 60mm housing and a 8 blade wheel for less than what it cost to buy a 60mm upgrade for my H1C. the turbo is off of a 1999 24valve and has a 60mm wheel from gillett diesel??
is it worth it being the truck only has 140,xxx and was only used as a daily? not sure wich to go with right now
Last edited by jdbigblue12v; 11-29-2011 at 11:57 PM. Reason: Automerged Doublepost
avatardvr
18
08-08-2019 12:38 AM
Hogridenfool
11-20-2017 04:37 PM
huntman7
8
08-28-2015 05:42 PM
n2brk
02-21-2015 09:05 AM
GreenDieselF
10-20-2014 02:05 PM
Quick Reply: HX35 Turbo Or Compressor Upgrade
