2002 Powerstroke Valves and Valve Springs Information
Valve Springs
OEM Part Number - E4TZ6513C
Price Each - $1.63
Valve Keeper
OEM Part Number - F4TZ6518A
Price Each Half - $0.25
Valve Seals
OEM Part Number - F4TZ6571A
Price Each - $3.18
Valve Cover Gasket
OEM Part Number - F81Z6584AA
Price Each - $81.52
Intake Valve
OEM Part Number - F4TZ6505C
Price Each - $38.24
Exhaust Valve
OEM Part Number - F4TZ6507B
Price Each - $30.51
Valve Grind Gasket Kit
Includes: Valve Cover Gaskets, Head Gaskets, Intake Manifold Gaskets, Valve Seals And Thermostat Gasket.
OEM Part Number - F4TZ6079CCC
Price Each - $264.03
Valve Spring Compression
Note: Pressure lbs.@specified height Intake 71-79 lbs. @ 1.833 in
225-249 lbs. @ 1.352 in
Exhaust 71-79 lbs. @ 1.833 in
Valve Spring Free Length (Approximate) Intake 2.075±0.150 in
Exhaust 2.075±0.150 in
Valve Spring Assembled Height Intake 1.767 in
Exhaust 1.833 in
Valve Spring Out of Square-Maximum 0.078 in
Valve Stem-to-Guide Clearance (Max) Intake 0.0055 in
Note: Service clearance-.0055.
Exhaust 0.0055 in
Valve Face Angle Intake 30°
Exhaust 37.5°
Valve Face Runout-TIR Maximum 0.002 in
Minimum Valve Face Margin-Intake Valves 0.066 in
Minimum Valve Face Margin-Exhaust Valves 0.054 in
Valve Stem Diameter 0.31185-0.31255 in
Valve Head Recession Relative to Deck Surface Intake 0.046-0.058 in
Exhaust 0.052-0.064 in
Price Each - $1.63
Valve Keeper
Valve Seals
Price Each - $3.18
Valve Cover Gasket
Price Each - $81.52
Intake Valve
Price Each - $38.24
Exhaust Valve
Price Each - $30.51
Exhaust 1.833 in
Exhaust 0.0055 in
Exhaust 37.5°
SonicDiesel99 (05-26-2010)
