Oil Pressure?
Old 07-19-2008, 03:17 AM
JS2TZU's Avatar
Default Oil Pressure?
whats the normal operatring oil presure for my dually? Is there a diffrence in pressure between gas and diesel engines? I only ask becasue it really fluccuates(sp) alot. Normal driving is right around 20 and when I get up on it it jumps up to about 60 when im idiling its at around 10 or so. Is this normal?
My 6.0 2500HD has always been a constant 60 from the day I bought it and ive always assumed this was normal.
Thanks in advance!!
Old 07-19-2008, 04:08 AM
stkdram55's Avatar
im not real sure with the DMAX's but that seems kinda low, i wouldnt think it should drop down to ten. What weight oil are you running.
JS2TZU (07-19-2008)
Old 07-19-2008, 12:30 PM
jdugie123's Avatar
yes that is normal for the dmax it doesn't really need much oil pressure it is a little hard to get use to but it is normal every dmax i have been in has been that way
JS2TZU (07-19-2008)
Old 07-19-2008, 12:47 PM
JS2TZU's Avatar
ok cool! Yea it worried me a little the way it moves around so much
Haha I have yet to change the oil since i bought it from the dealer. What would you recomend?
Old 07-19-2008, 01:08 PM
Woody35's Avatar
i dont know about Dmaxs but everytime im in the ford work tractor the oil pressure goes up as the throttle increases. i aways assumed that as the engine worked harder the more oil it needed
Old 07-19-2008, 02:05 PM
2500HeavyDuty's Avatar
wouldn't be normal for me
Old 07-21-2008, 10:01 PM
Rttoys's Avatar
Yep, it's normal for LLY and up. Right now I'm towing 14000#, doing 65mph, 1800rpm and showing 40psi. High volume/low pessure.
As for oil: Delco PF2232 oil filter and regular Delo400 for me, others will say what they like, I'm sure.
Old 07-21-2008, 10:29 PM
i think ill call u mr.delco.
But they make some darn good stuff
Old 07-22-2008, 12:23 PM
jdugie123's Avatar
well the pressure is always up if you never lift off the throttle hahaha
Durtyd09
11-11-2015 01:43 PM
purnell82
07-22-2015 10:42 AM
jhprice
03-29-2015 09:36 PM
powerstroke4178
11-27-2014 02:35 PM
Jeremy Babb
Chevy/GMC Duramax 01-04 LB7
13
10-01-2014 06:27 AM
Quick Reply: Oil Pressure?
