oil pan gasket leak fix?
Old 10-18-2008, 02:52 AM
Queeg's Avatar
Default oil pan gasket leak fix?
Ok so the only thing on my truck that leaks is my oil pan gasket! Is there anyv way to fix it w/o pulling or lifting the engine?
Will silicone do the trick?
If I can't fix it ill have to park on the street, and that won't happen ever.
Old 10-18-2008, 03:19 AM
I would look into either of these:
Anaerobic gasket maker: Loctite 37394 - Loctite 518 Anaerobic Gasket Maker - summitracing.com
or
The Right Stuff: http://www.permatex.com/brand_right_stuff.htm
Im not sure how clean you have to get the mating surfaces.
Queeg (10-18-2008)
Old 10-18-2008, 03:23 AM
stkdram55's Avatar
No you have to unbolt the engine and lift it up about 3-4 inches to get the rest of bolts out of the pan but be careful not to lift it to high it will put too much strain on the tranny mounts just lift it high enough to get the bolts and pan out.
I doubt silicone will seal it good enough to make a difference plus that gets pretty warm down there so it might work for a little bit but not a permanent fix.
you can change the gasket in about 3-4 hours if you have the proper tools a cherry picker being the most important of em.
Is it leaking that bad or just a little spot when you park it overnight if thats the case i would just leave and keep an eye on your oil level every week or so.
Just remember..."My truck doesnt leak oil, its marking it territory"
Old 10-18-2008, 03:46 AM
Queeg's Avatar
Hahah tried that but my father told me otherwise! And I'm sick of pressurewashing and scrubbing.
Old 10-18-2008, 04:19 AM
For less than $10 its worth a shot.
Old 10-18-2008, 04:24 AM
stkdram55's Avatar
yeah true
Old 10-18-2008, 06:26 AM
gone ropin's Avatar
if you can get the pan to hang down some go to a specality plumbing store and get some teflon rope, (not teflon tape) make a round or 2 around the pan on the outside of the bolts and tighten it back up, poof leak gone! and no worrys about silicone plugging up your engine, and it will fill in any hi or low spots and a little bit of dirt or broken gasket in the way wont even phase it, been there done that
Old 10-18-2008, 12:23 PM
interesting....
Old 10-28-2008, 11:28 PM
jamiewood's Avatar
Site Sponsor - Southern Diesel Extreme
I did this on my sbc race motor. The timing cover was leaking oil and didn't have time to change the gasket (race day). So we took the ole trusty shopvac and put it on the crankcase breather ( in your case try the oil fill). This creates vacuum in the crankcase then you can dab the rtv around the oil pan and let the vacuum suck it in then dry. No leaks!
Old 10-23-2013, 10:13 PM
Clutch3500's Avatar
What size teflon gasket rope did you use? What kind? Whered you get it? Im having a hard time finding it
Quick Reply: oil pan gasket leak fix?
