P2509
Old 11-28-2008, 08:10 PM
Sluggo's Avatar
Default P2509
I'm sure somewhere on here is a list of the code's, but I'm not having any luck finding them. I did the key trick & got a P2509 could someone Please tell me what this is...Thanks
Old 11-28-2008, 08:29 PM
Oilfield_Mafia's Avatar
Sluggo, in the top left corner uner all the icons, it says Bomb Site, click that arrow down and you will see the link for OBD II Codes..
Or you can bookmark this link https://www.dieselbombers.com/codes.php
p2509 isnt coming up for some reason. Im sure one of the Dodge guys with a Factory Service manual can help.
Sluggo (11-28-2008)
Old 11-28-2008, 08:58 PM
Sluggo's Avatar
Your the Man...Thanks OM
Old 02-10-2009, 06:23 PM
cummins tech's Avatar
P2509-ECM/PCM POWER INPUT SIGNAL INTERMITTENT. I HAVE SEEN THIS CODE. ALL I HAVE DONE IS A FLASH TO THE ECM AND IT USUALLY FIXES IT
Old 02-11-2009, 02:08 AM
Sluggo's Avatar
I took it to the dealer,they checked it out & found I had a bad battery.. good volt's but low amps. They replaced batt. all is good now. was getting alot of CEL's ,was thinking they were emission related, turns out all it was, was a bad battery
