Truck will not warm up.
Old 12-15-2008, 05:46 PM
bonk's Avatar
Default Truck will not warm up.
I have a 94 Yukon with a 6.5L and the enging will not warm up. Temp gauge only comes up to second line on gauge. Have changed the thermostat and the fitting that comes off the water jacket. Have also changed the fan clutch as old one was locked up and wouldnt release. also changed heater core. Anything i am missing or any ideas what could be wrong.:argh:
Old 12-15-2008, 06:23 PM
wildbill's Avatar
Maybe it's cold enough to where you have to block the radiator with cardboard.
Old 12-15-2008, 07:30 PM
bonk's Avatar
Just put some in, Havent gone anywhere to see if it works or not yet. We changed the heater core cause there is very little heat in the cab.
Old 12-15-2008, 07:38 PM
wildbill's Avatar
Don't worry about it overheating cruising down the highway/freeway empty if you forgot to remove the cardboard. Mine stays just below 200.
Old 12-15-2008, 07:48 PM
bonk's Avatar
not worried about o/h right now. -45 celcius in the wind
Old 12-15-2008, 08:18 PM
Patches's Avatar
i asume none of the coolant is dissapearing?
Old 12-15-2008, 09:00 PM
bonk's Avatar
No none of the coolant is disappearing. The cardboard did get me one more line on the gauge. I still have the top half of the fan shroud off from changing the fan clutch this afternoon. Would that make a difference?
Old 12-15-2008, 09:05 PM
wildbill's Avatar
It would a little bit, because the shroud helps the fan suck more air from the outside of the radiator to the inside.
Old 12-16-2008, 10:05 AM
K50's Avatar
K50
K50 is offline
Are you in N.Canada?
Old 12-16-2008, 02:29 PM
bonk's Avatar
No i am in Regina.
Quick Reply: Truck will not warm up.
