Squealing Turbo
Old 03-04-2009, 07:13 PM
ccrider's Avatar
Default Squealing Turbo
I have an '04 F350 w/6.0. I just put on my Elite EGR Delete kit, the Edge Platinum Juice w/Attitude, a Volant Ram air filter, and Silverline 4" dual exhaust turboback. All went well. Upon test driving it for results, the turbo started up with a high pitch squeal...kind of like a burned bearing, but not one. It's not a whistle. Did a 1/4 mile run with the Juice Edge and turned a 15. Squeal persisted all the way through. Water pushed back and overflowed through the reservoir. Can anyone tell me what's going on? The engine never heated up and produced 26 lbs. of boost. Why the squeal and why the overflow? Thanks for any help out there.
Old 03-05-2009, 08:01 AM
wildbill's Avatar
*wildbill copied
Old 03-07-2009, 09:36 AM
hock6.0's Avatar
Are your headgaskets bad. When mine went i couldn't get more than 25 psi boost and it constantly blew fluid out the degas bottle.
Old 03-07-2009, 10:02 PM
Big Angry Hillbilly's Avatar
If it's pumping coolant out the degas bottle, it's either the cap, the bottle, or heads. I would bet my money on heads, especially if you don't have it studded.
Take all that aftermarket **** off and try and get it done under warranty.
Old 07-06-2009, 10:06 AM
all fired up's Avatar
I have an o4 that i just had my heads studded and egr delete kit and mine is squeeling too, did you get any good info on youres yet? i dont have mine chiped or even a cold air intake on it, but every time i pull a load it squeels up hills and on take offs.
Last edited by all fired up; 07-06-2009 at 10:07 AM. Reason: i forgot, its still loosing coolant too!
Old 07-17-2009, 10:44 PM
Exhaust leak(s) at the turbo-up pipe bellows, as well as the outlet port to the EGR cooler can cause this.
Depends on how you deleted your EGR
Old 07-18-2009, 03:24 AM
HeavyAssault's Avatar
Seems like there might have been something that was not installed properly. Did you do the delete yourself?
Old 07-18-2009, 10:23 AM
Squealing can also be pressure escaping from radiator cap. Have seen this on several trucks, too.
Old 07-26-2009, 07:03 PM
04redstroker's Avatar
Could be stuck vanes, but that usually doesnt cause a squeal. Also, I would recomend gettin rid of the edge, they arn't the best for the 6.0. The pukin could be caused by failed HGs, improperly installed egr delete, the degas bottle cap, and even the water pump.
Old 10-19-2010, 09:02 AM
MUDSTROKIN''s Avatar
Ever figure this out?
avatardvr
18
08-08-2019 12:38 AM
Finn92
02-24-2015 10:41 PM
n2brk
02-21-2015 09:05 AM
jrsavoie
02-06-2015 09:44 PM
GreenDieselF
10-20-2014 02:05 PM
Quick Reply: Squealing Turbo
