testing your CPS*
Old 07-01-2009, 04:57 PM
RSWORDS's Avatar
Default testing your CPS*
Ok here is the way to test your CPS.
Black/blue tracer is the sensor ground wire. It should OHM close to zero to the battery ground.
Tan/yellow tracer is the 8 volt power feed to the sensor. The voltage regulators on the PCM's are kind of loose. This voltage can vary around some.
Gray/black tracer is the signal wire. If the sensor is on a smooth section of the balencer there should be little if any voltage showing. When the sensor is on one of the air gaps it should show around 5 volts.
If you have a 12 volt adjustable power supply. A 14 gage blue wire terminal will slide down over the male pins on the CPS.
09-29-2015 12:50 PM
08-23-2015 06:10 PM
07-08-2015 05:50 PM
02-16-2015 02:00 PM
01-20-2015 03:01 AM
Quick Reply: testing your CPS*
