what's the best programmer to get?
Old 07-19-2009, 06:21 PM
cjdeere's Avatar
Default what's the best programmer to get?
Hi gang, what would be the best programmer for my stock '06 cummins? The only thing I've done to it was put a Magnaflow muffler on it and put an open pipe from the turbo to the Magnaflow muffler. I would like to start with a programmer for some added power, mileage and maybe some smoke every now and then...Thanks guys
Old 07-19-2009, 07:11 PM
Redpatcher0481's Avatar
Smarty But at the same time you should get some gauges to monitor things.
Old 07-19-2009, 07:20 PM
cjdeere's Avatar
Ok, I'll check it out and the gauges. Thanks
Old 07-31-2009, 04:19 PM
North Pole Hooker's Avatar
Next week my Hypertech Max Energy will find it's long, slow way to Alaska, and I'll let you know what it does. According to Hypertech's Dyno, the 6-speed gains +176 HP and +289 TQ from the '05-'07 Cummins with a 6-speed. A bit less with the automatic at +113 HP and +185 TQ. I've read that guys have put the level 3 (highest) program in and have achieved a 2-3 MPG increase. I'll have to see this for myself, though. I sold the idea to my wife on the grounds of MPG increase, as diesel is $3.39/gal up here in North Pole, Alaska. Best price for it was $319 at 4wheelonline.com, saved about $60. Give me a few tanks of coal and a few days of driving and I'll let you know.
Old 07-31-2009, 05:31 PM
1badcummins's Avatar
smarty love my smarty
Old 07-31-2009, 05:56 PM
fuelinblood84's Avatar
smarty's are bad *** but this new TST PowermaxCR PDA49 is supposed to get 200hp and 600ft lb tq at the rear wheels color display for pyro, boost, tach and rail pressure. That may be more than what you want but you can contact them out TST Products, Inc.
Old 07-31-2009, 11:39 PM
Hummin Cummins's Avatar
I have both the smarty and the TST( Not the new PDA one)
I like the TST for pulling the best. The TST is a little harder to install just have to follow the instructions.
The smarty has better low end grunt and simple to install and remove one conector and push a few buttons.
If I had to choose I would take the TST.
Old 07-31-2009, 11:45 PM
wildbill's Avatar
I've ran both the SR n JR Smarty. Both flashed the ECM from stock to power and back with no problems. Never had it completely erase the ECM either. If you want some or a lot of power, go with the JR.
But remember, they all raise rail pressure which shortens the life of the injectors.
Old 08-01-2009, 12:09 AM
Smarty or Adrenaline
Old 08-02-2009, 01:32 AM
cjdeere's Avatar
Thanks guys, I'm gonna go with a Smarty Jr. and some gauges...for me, I think that's the best way to go. Thanks again for the info
Quick Reply: what's the best programmer to get?
