lower egt's brainstorming
Old 08-17-2009, 12:09 PM
Rocky Mountain Texan's Avatar
Default lower egt's brainstorming
Come on guys i want to hear everyons ideas on how to lower egts.
also one more question, Can you apply 2nd gen 12 valve. exhaust and turbos to a first gen?
Last edited by Rocky Mountain Texan; 08-17-2009 at 12:09 PM. Reason: Automerged Doublepost
Old 08-17-2009, 12:29 PM
stkdram55's Avatar
Bigger turbo, Better Intercooler, Air intake, Water Injection, Nitrous...
I think the turbo will work and maybe an exhaust manifold off a 12v to a 1st gen...i dont think the actual exhaust pipe will fit though
Old 08-17-2009, 01:25 PM
tower_ofpower's Avatar
downpipes dont interchange. 2nd gen turbo's are wastegated and run a larger flange. i've heard that the downpipe for an HX-40 is pretty much universal for updated turbo's on the first gens and some small tweaking for clearances may be need. there's a thread on here that says if your going to put a stock turbo on from a different year they recommended the HX-35- i cant remember what the last digit is. but it's off of the 03ish 5.9L i guess it's decent; but the price jump from that to a REAL good used or new aftermarket isnt bad... maybe an extra 400? someone jump in and correct me if i'm wrong... i guess my advice would be... dont jump the gun. save your money and get something you're going to 100% happy with. by the time you go into the expense of a new model exh. housing and turbo your going to be pretty close to buying a better turbo than the generation swap
Old 08-17-2009, 04:36 PM
RSWORDS's Avatar
Look around for my exhaust and turbo thread. I put a HX40 style down pipe on my 1st gen and all it took was a little tweaking of teh fire wall with a hammer.
Old 08-17-2009, 09:47 PM
i belive it is under the rotary bombers labeled "things are falling off my truck and this time it's the turbo"
Old 08-19-2009, 02:22 PM
Gunmetal's Avatar
I was under the impression you could install a cast exhaust elbow from a second gen and that would allow you to run a 4" 2nd gen down pipe.
Notdaddysmoney
11
10-23-2015 12:52 AM
CCPerformance.com
Chevy/GMC Duramax 2011 LML
09-01-2015 11:37 PM
CumminsCoalRoller24/7
05-25-2015 09:04 PM
Moparts345
05-24-2015 09:35 AM
Curry
04-20-2015 04:04 AM
Quick Reply: lower egt's brainstorming
