Wont start after sitting for a few days...any ideas????
Old 08-31-2009, 01:54 PM
Edge33's Avatar
Default Wont start after sitting for a few days...any ideas????
So the truck has an unusual problem, after it sits for a few days it wont start, it cranks but takes a bit to fire. It doesnt throw any codes either. Im assuming im getting air in the fuel system some how. The drive way has a slight angle but nothing drastic. Any suggestions? Thanks.
The dealer said its not uncommon !!! hmmm i have to disagree
Old 08-31-2009, 02:18 PM
mysterync's Avatar
Sounds like your fuel filter is leaking down. I've seen 4 or 5 do it.
I would change the filter and O-rings, and then look towards the rest of the supply fuel system!
Old 08-31-2009, 03:10 PM
j johnson's Avatar
also look at the water in fuel sencer at the bottom of the fuel filter the drain has been knowen to leak...sometimes it wont leak on the ground but just anuff to let in air...hope this helps!!
Old 09-01-2009, 05:05 PM
Edge33's Avatar
Thanks guys ill check into both...
Old 09-07-2009, 12:32 PM
BriteWhiteRam's Avatar
even just not getting the fuel filter tight enough will do it, also, try to reprime the system and see if that helps
Old 09-07-2009, 03:46 PM
mysterync's Avatar
If it's more than a filter, it could be a CP3
moparisthebest
23
10-15-2015 12:13 PM
Cavnar
09-09-2015 07:18 PM
IGOU
03-08-2015 04:25 PM
ronstop
02-26-2015 09:48 AM
carid
Diesel Bombers Sponsors
11-18-2014 06:49 AM
Quick Reply: Wont start after sitting for a few days...any ideas????
