47re line fittings?
Old 09-07-2009, 02:33 PM
razorrodent's Avatar
Default 47re line fittings?
I need to replace my transmission cooler hard lines with -AN line becuase its rusted cracked and leaking. I already have added a aux derale cooler to it using compression fittings on the stock 1/2" tube but I would like to put _AN fitting directly on the trans. Does anyone know what -AN to what ever adapter fitting is needed for the cooler in and out lines?
Old 09-07-2009, 04:02 PM
I am pretty sure JKM knows the answer to this. Send him a PM.
Old 09-07-2009, 07:37 PM
bluetj's Avatar
I used a 1/2 in hard line to -8 fitting for mine. I think it was a Russell fitting. I have an extra still in package in the garage I'll check the part# later. I just left a short piece coming out of the trans that wasn't rusted and used these because I already had them. Worked good and after a year still hasn't leaked. Are you trying to get rid of all the stock line?
Ok, I used a Jegs fitting part#100553. JEGS 100553 JEGS Hard-Line AN Adapter Fittings. I believe the thread in the trans case is 1/2 npt. I also used jegs push loc hose and AN fittings. You want to use -8 because that is equivelent to 1/2 like your stock line. JEGS AN to NPT Adapter Fittings - JEGS here are some AN to NPT adapters that would thread right into the case if it is 1/2 NPT. Hope this helps you out. Good luck with replacing the lines. I think I'm going to do the rest of mine since I have to work on the trans again anyways.
|WYG|SS
05-07-2015 04:57 AM
03-02-2015 05:10 PM
02-12-2015 03:10 PM
12thman
01-20-2015 03:22 PM
motormayhem
11-16-2014 02:13 PM
Quick Reply: 47re line fittings?
