cab mounts?
Old 09-27-2009, 11:07 AM
2low4nh's Avatar
Default cab mounts?
Okay so i just bought a 95 2500 withthe cummins in it. I am starting to rplace body panels but i hit a snag. The passeger side floor is roted as well as both front cab mounts o the floor portion. does anyone know where i can buy these? do the replacement oor sections come with new cab mounts? Please help i need to finish this truck within 2 weeks
Old 09-27-2009, 11:52 AM
Uncle Bubba's Avatar
By cab mounts are you talkin about the rubber cab mounts or the steel that they bolt into rotten.
Old 09-27-2009, 01:01 PM
12vcummins96's Avatar
the cab mount can be bought or made if you have the capibility just look at the other side and copy it
Old 09-27-2009, 06:58 PM
2low4nh's Avatar
im talking about the metal part thats welded to the floor. both sides are kinda shot. i will fab some u if i have tobutim not looking forward to that. they ar actually pretty rugged looking pieces. if you look at them under the tuck the rocker panel end of them is rotted almost all th way off. th pasenger side actually cracked the floor boards.
Old 09-28-2009, 12:35 AM
Just from the sounds of it this doesn't look like it's gonna be a two week project, or even a two month project unless you have a shop do it and the price isn't gonna be right there. I really hope you take a good look at all the other parts of the truck here to make sure the project is even gonna be worth the trouble. Sounds to me like this is either a scrap yard project or a full restoration. Sounds like they parked it in the ocean for a while.
Old 09-28-2009, 04:51 AM
2low4nh's Avatar
no it was jst driven in mass! i bought new fenders rockers and cab corners for it just need the cab mounts
Old 09-28-2009, 10:42 PM
SinnerRacing52's Avatar
i think urs did the same as mine so heres wat i did i jacked the cab up and bent the floor back in place cut the floor boards out and made new ones. i then welded the new floor boards in and welded the cab mount to it and reinforced the cab mounts with angle iron and steel plate and it took me about 3 hours is all but both side cab mounts were messed up.
Old 09-29-2009, 03:44 PM
2low4nh's Avatar
yep i am fabricating some new mounts! just an FYI for everyone!!!! you can not buy these anywhere bu from a junkyard!!!!!!! dodge does not sell or produce these parts and no aftermarket manufacturers make these! i called everywhere dodge told meto go to a junk yard.
corksil
Ford Powerstroke 99-03 7.3L
06-27-2015 03:15 PM
scubasegt
06-09-2015 12:07 PM
Doug C
04-13-2015 08:20 AM
RHIT_Cummins
12-16-2014 10:14 AM
Jthompson_32
10-05-2014 09:51 PM
Quick Reply: cab mounts?
